Normalize contour on cut-plane
Old   January 28, 2015, 09:28
Default Normalize contour on cut-plane
star123 is on a distinguished road
When I plot the mass flow on a cut-plane by using local range, could it be possible that I can plot the normalized contour value on the plane (mass flow local/mass flow Max)?
Thanks!
star123 is offline   Reply With Quote
Old   January 29, 2015, 07:46
Sun
Sun's Avatar
Sun is on a distinguished road
I guess you can have a "custom field function" as the normalized mass flow and then plot this new field function.
Sun is offline   Reply With Quote
View with cut plane Mudblood FLUENT 5 April 4, 2020 10:17
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ANSYS Meshing] Cut Plane Problem cfdizzle ANSYS Meshing & Geometry 0 December 4, 2014 15:54
Creating Contour Plots on a Rotated plane maalaniz FLUENT 0 August 22, 2014 20:14
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position zhoubinwx ParaView 3 February 13, 2008 04:46
