pressure outlet of orifices
Old   February 3, 2015, 07:43
Default pressure outlet of orifices
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey friends
I should compare two different orifices in fluent but I have an issue!
I have physical properties of the liquid, geometrical properties of orifices and static pressure at inlet
But I need to calculate the pressure of outlet for each of them
I'm confused to selecting an appropriate outlet boundary for calculating pressure at outlet!
any ideas friends?
amin.z is offline   Reply With Quote
Old   February 5, 2015, 05:06
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Amin, I would draw a long pipe next to the plate, so to have a completely developed fluid; and then I would set outflow bc to let fluent calculate the pressure drop.
Daniele
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   February 5, 2015, 05:16
amin.z's Avatar
Amin
Daniele
Hey dear friend
I'm used this method, I used a long channel after the orifice, my inlet BC is pre. inlet and outlet BC is pre. outlet.
But the pressure distribution is strongly dependent to outlet gauge pressure while I haven't any information from outlet!
Old   February 5, 2015, 05:20
ghost82's Avatar
Rick
No amin,
I suggested to set the inlet as velocity or mass flow inlet and the outlet as outflow (because you have no info about pressure/velocity distribution, and pressure inlet is not compatible with outflow).
You need completely developed flow to apply the outflow bc.
However, take care to your problem, and take care where these orifices are installed: I did some simulation about cavitation in orifices.
The plates were installed next to a pump, in a closed loop; Tank-->pump-->orifice-->tank and so on.
Pressure outlet was always atmospheric, independently of the pressure inlet given by the pump, because the tank was open to atmosphere.
Old   February 5, 2015, 05:29
amin.z's Avatar
Amin
But mass flow inlet is one of the unknown values of the problem
But maybe velocity inlet could help me!
Good idea dear friend! Tnx!
And another question! is this method suitable for ideal gases? Compressible flows...
Old   February 5, 2015, 05:34
ghost82's Avatar
Rick
If you have the static pressure at inlet you can go for trials and errors to get a correct velocity inlet.
Moreover, if you know velocity at inlet and you know the properties of the liquid, then you know also the mass flow inlet.
It should be applied to gases also.
Old   February 5, 2015, 05:37
amin.z's Avatar
Amin
Good! You're right!
Thanks for benefit help!
Old   February 9, 2015, 01:40
amin.z's Avatar
Amin
"The use of outflow boundary condition is not appropriate for
a compressible flow problem. Please change the zone
types of all outflow boundaries." Fluent said!
Old   February 9, 2015, 08:21
ghost82's Avatar
Rick
Yes, outflow is not valid for compressible flow (sorry I didn't read your gas was compressible).
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
unknown pressure at outlet akashmpatil FLUENT 0 April 10, 2014 15:25
Pressure outlet BC help! eishinsnsayshin FLUENT 7 December 3, 2012 23:36
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
Pressure Outlet setting CoG STAR-CCM+ 4 June 9, 2010 21:47
