problem with using fan BC to simulate turbine. |
June 1, 2015, 23:15 |
Hi forumers. I'm using fan BC (with and without rotation )to simulate a turbine.
I've got a and a' by BEMT and applyed it to fan BC. And fan was set as △P=2ρa(1-a)U^2(for both conditions) and Vθ=2Ωra'(equals 0 if rotation is neglected) and radial velocity is 0(for both). steady k-e was used Results shows: (dot is experiment results and thin blue line is cfd result) 1.without rotation 2.with rotation you can see that results of model without rotation is acceptable. however model with rotation shows an acceleration of wind speed at bottom area. could anyone tell me why does it happpen? is it wrong with the equation of △P=2ρa(1-a)U^2 and Vθ=2Ωra' ? or if i add source term in N-S, instead of use fan BC, shall solve this problem? pls feel free to ask any question and contact me! thank you guys! |
actuator disk, fan bc, turbine |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
How to simulate a fan without the geometry of fan? | swtbkim | CFX | 7 | November 11, 2014 00:18 |
help to simulate wind turbine | mehrdadm_1989 | FLUENT | 0 | April 8, 2013 11:37 |
Wind turbine simulation problem | sanchovg2 | STAR-CCM+ | 12 | March 5, 2013 04:18 |
simulate a cht problem | Chris | Siemens | 3 | November 29, 2006 04:25 |
