July 2, 2015, 01:22 |
Fluent
SHEIKH NASIRUDDIN
Rep Power: 12 |
Dear all,
In LES run , I saw a peculiar problem and want share it with you all. I defined a point in the domain i.e. y_vel_10rad_ to get temporal quantities. Then I continued simulation and saw that an extra scaled residual under the head y_vel_10rad_ (as highlighted in the attached image) apart from x,y,z and continuity. Can any body help me, how to remove it, because of it solution is not converging. Thanks, Nasiruddin |
July 2, 2015, 13:27 |
Lucky
Rep Power: 66 |
It looks like you have made a monitor and probably checked print to console. Simply uncheck it in gui or disable print in tui.
Connecting Fluent benefits and Injection Molding Software | Jim87 | FLUENT | 1 | August 6, 2023 16:06 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 08:20 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
