Problems when modelling flow through syringe, error in dynamic initialization
Old   September 1, 2015, 01:43
Default Problems when modelling flow through syringe, error in dynamic initialization
Sudir
Sudarsan1805 is on a distinguished road
I am trying to model the flow of fluid through a syringe. I am using a simple syringe structure, yet I am not able to get results. I think there is an issue with the meshing of the syringe. The error which I get when I initiate dynamic initialization is convergence factor not reached. Also, I have attached the picture of the syringe and the error during the meshing.Capture.jpg
Last edited by Sudarsan1805; September 1, 2015 at 01:45. Reason: Forgot to add attachment
Sudarsan1805 is offline   Reply With Quote
Old   September 1, 2015, 06:18
Devesh Baghel
devesh.baghel is on a distinguished road
Have you really taken only fluid domain for meshed model as posted ?
What is the dimension of syring and mesh size in your simulation ?
Devesh
devesh.baghel is offline   Reply With Quote
Old   September 1, 2015, 16:53
Lucky
What about using a standard initialization procedure? Shouldn't that still work?
It would be conducive to fix any meshing errors before discussing Fluent errors. Nobody wants to discuss problems with Fluent while your mesh is questionable. It sounds like you have a meshing problem and not a Fluent problem.
Old   September 2, 2015, 02:19
Sudir
LuckyTran, Like you said, solving is secondary. There is no point in me trying to solve the problem without the meshing being made accurate
Devesh, I didnt get quite what you meant by Fluid Domain. Sorry, I am just a week into CFD. Can you please elaborate what that means. And the size of the syringe is about 8 cms. I have tried using the default mesh settings , as well as reducing the mesh size upto 0.01 mm and using a 5 deg angle with fine transition. I am still getting the same error.
bad boundary mesh, fluent, meshing, syringe
Problems modelling developed flow on inlet Allankey CFX 3 May 25, 2014 18:52
UDF problems with porous flow Nicolastheterminator Fluent UDF and Scheme Programming 0 April 8, 2014 09:12
initialization of flow field in a transient flow calculation zhengjg FLUENT 1 January 15, 2014 06:01
problems with mass flow in DPM matiashess Fluent UDF and Scheme Programming 0 November 15, 2013 16:23
Question Regarding Modelling Internal Flow Alteran CFX 1 September 4, 2013 12:07
