High pressure at the end of compression stroke
Old   December 26, 2015, 10:03
Default High pressure at the end of compression stroke
Pawan Meena
Pawan30 is on a distinguished road
I am simulating the compression stroke of a Diesel Engine in ANSYS ICE workbench.As, the piston move upward in the compression stroke, just before the injection the pressure calculated by the simulation is more than the actual pressure corresponding to the experiment.The actual value is about 20bar but from the simulation the pressure is calculated about 80bar.I am not getting, why the pressure is rising so much ??
How to solve this problem ??
Pawan30 is offline   Reply With Quote
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
