How can I get the max temperature?
Like Tree1Likes
  • 1 Post By hotboy
Old   January 2, 2016, 21:43
Default How can I get the max temperature?
wanghuo
hotboy is on a distinguished road
Hello friends!
Now I was modeling a 3D geometry(a big geometry contain many small geometry ).If I want to get the max temperature of one small geometry ,which report type is the best choice?There are many max temperature such as suface integrals-Facet Maximum ;Surface integrals-vertex maximum ;volume integrals-maximum .I found that the value of them are different.Which is the true max temperature of the small geometry that I was interested in.
When I display the temperature coutours of the geometry I found that the max temperature are different whether I choose the "node values ".Which is the max temperature(choose the node value or not choose?)
Thank you in advance!
nadia.p1996 likes this.
hotboy is offline   Reply With Quote
Cavitation around NACA hydrofoil using interPhaseChangeFoam Kozan OpenFOAM Running, Solving & CFD 28 March 11, 2023 23:30
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 04:03
