question about modeling and setting up boundary between volumes
Old   January 7, 2016, 13:47
Default question about modeling and setting up boundary between volumes
Aja
aja1345 is on a distinguished road
I am simulating a turbine and I have doubt about modeling this turbine whether I am right or not.
In this turbine, there are three volumes.
The two volumes are the piping before and after the blade and the other volume contains the turbine blades. The domain containing the blades rotates at 2000 rpm=209.43 rad/s while the other two volumes are stationary.
I modeled this turbine in Gambit. and also I
split a large volume to create three mentioned volumes. that is,There is same boundary face between volumes and I didn't created the three volumes separately.
In this case, Is there any problems? Am i right? Because Gambit is weak for modeling this stage. What is your opinion?
In this work, the mesh node locations are identical at the boundary where the two zones meet.
I am grateful that guide me.
thanks.
Best.
Aja
aja1345 is offline   Reply With Quote
Old   January 7, 2016, 14:56
Aja
What is the exact meaning of "connected" option." in the following sentences?
"If you split a large volume to create two volumes, then you might have forgotten to turn on the "connected" option."
Boundary conditions for RAS turbulence modeling HerrSchein OpenFOAM Pre-Processing 0 August 4, 2015 09:25
Modeling interface of fluid and porous, not with default setting ftab CFX 27 May 20, 2014 06:58
modeling a food oven: setting Boundary Conditions jrsilvio_ver OpenFOAM Pre-Processing 3 March 22, 2014 18:51
Question about time step setting for different turbulence modeling Anna Tian Main CFD Forum 1 November 19, 2012 02:09
Setting Opening Boundary to Move Normal to Itself NCle CFX 10 April 20, 2012 07:54
