How to calculate pressure drop between inlet and outlet at interior surfaces? |
March 5, 2016, 13:09 |
Reslan Technical
Rep Power: 10 |
hi
can any one tell me how can calculate pressure drop between inlet and outlet at interior surfaces. i am not sure what to use mass or area weighted average. |
March 5, 2016, 19:42 |
Lucky
Rep Power: 66 |
Static pressure drop should be an area-weighted average. For example if you are trying to calculate the friction factor or pressure drop through a pipe.
March 6, 2016, 00:45 |
Thank you very mach
Reslan Technical
Rep Power: 10 |
Thank you very mach
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 10:19 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
