Dynamic Scenario Help
Old   March 22, 2016, 09:57
Default Dynamic Scenario Help
Conduit is on a distinguished road
Hello all, firstly some background upon myself. I am currently studying a MEng degree in mechanical engineering and as a part of a project I will need to model a CFD scenario within a circular pipe that is set to deform. It is based upon the compression of the pipe to reduce its cross sectional area at a point and for it to then if possible return to its original cross sectional area.
An example scenario for reference is a 150mm length circular pipe with a consistent cross section of 20mm. The inlet speed is a consistent fluid of 1m/s. The aim would be to reduce the cross section to 10mm over a period of time from which it can then return to the original geometry.
I am a novice at Fluent and can only run simple analysis at this current moment. What I am asking is how the pipe deformation could be modeled in Fluent. It would require the pipe wall compression over a period of time from which changes in values can be found.
Is it completed using the moving wall tool or is a dynamic mesh needed to be setup?
Are there any guides which highlight a similar scenario/technique as the ones I have found thus far have not been beneficial?
Will a 2D or 3D scenario be best for modelling based upon my previous Fluent Experience? (Is the step to 3D dynamic modelling a large gap to bridge?)
Overall just some potential pointers/confirmation that the task can be completed would be greatly appreciated. Thanks all in advance
Matthew
Conduit is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
Dynamic SGS model procedure in Large eddy simulation mrf6166 Main CFD Forum 39 November 25, 2016 14:13
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 05:14
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
