How to set up a mixing tank with double helical ribbon blades |
April 26, 2016, 21:52 |
Luke
Hello all,
I have model of a double helical ribbon blade impeller that I imported into ANSYS where I created an enclosure the size of my mixing tank around the blade impeller and did a boolean subtraction, so that I could model just the fluid. My biggest issue though is setting up the initial boundary conditions inside Fluent for a single phase flow analysis. Could anybody give me any suggestions? I have heard that I can have the blades stationary while I have the fluid body rotating which eliminates the need for interface zones..? and I have also heard that I can set the blades in motion while the fluid is stationary? Thank you for the help! |
boundary conditions, fluent, impeller, interface zones, mixing tank |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Interpret-Real Gas UDF | ndabir | Fluent UDF and Scheme Programming | 3 | November 18, 2015 07:29 |
[swak4Foam] #codeStream options & includes, swak4Foam | dEntropy | OpenFOAM Community Contributions | 10 | July 29, 2015 05:10 |
[DesignModeler] Modelling mixing tank using MRF approach | Natali | ANSYS Meshing & Geometry | 0 | March 17, 2015 06:26 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
