July 13, 2016, 06:30 |
Liquid level VOF model
Ignacio
Rep Power: 13 |
Hello everyone,
I am using the VOF to model a pool and a gas space, with a velocity-inlet boundary condition injecting water at the bottom of the tank. The rest of the boundaries are walls with no-slip. I am using a 2D axisymmetric model (with x-axis set as axis of rotation). Checking the Report>Fluxes>Mass flow rate>Net shows that I am injecting a correct amount of water through the velocity-inlet boundary condition. However, the liquid level in the pool increases at a much slower rate than what it should, based on the injection rate . What could be the reason for this? I have double checked the density of the fluids, pool dimensions, mass flow rate injected into the pool, and they seem to be correct. Thanks in advance! =) Ignacio |
[snappyHexMesh] meshing of very small patches in comparison with the overall geometry | christos | OpenFOAM Meshing & Mesh Conversion | 3 | December 17, 2014 16:55 |
Mixture model + VOF? | blacksoil2012 | Fluent Multiphase | 2 | February 8, 2014 23:59 |
VOF - Eliminating shear on the surface of a thin liquid film | saisanthoshm88 | Fluent Multiphase | 0 | October 27, 2013 12:22 |
Diffrence between VOF alone and VOF coupled Level 7 ?? | Valeck | Fluent Multiphase | 10 | August 19, 2013 04:22 |
VOF model | heri | FLUENT | 6 | April 22, 2008 11:02 |
