Negative Total heat flux at inlet
Old   August 18, 2016, 01:53
Default Negative Total heat flux at inlet
Tleja
Tleja is on a distinguished road
Hi All!
I'm not familiar in heat transfer field. I'm studying fluidized bed reactor with transient study.
In my system, solid particle was patched at the bottom of reactor. Then, i continuously fed gas and solid with 343K temperature. I also initialized this system with 375K.
After starting calculation, i found that total heat flux of gas and solid at feed inlet are negative value. As my understanding, total heat flux should be equal to mass flow rate*heat capacity*(T in-T ref) which is certainly positive value. i also checked that mass flow rate of gas and solid at inlet are positive value.
I don't know why total heat flux is negative value at inlet.
Please anyone advice me to solve this problem.
Thank you so much.
Best regard
Tleja
Tleja is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
setting heat flux inlet boundary condition eliminator CFX 6 July 28, 2015 08:50
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 00:27
Total Surface Heat Flux cfmyd FLUENT 0 June 27, 2014 16:00
Total heat transfer through pressure inlet Naher FLUENT 4 June 13, 2011 10:22
