Characteristic length in Rayleigh number
Old   August 21, 2016, 02:01
Default Characteristic length in Rayleigh number
a0407
azizi0407 is on a distinguished road
Hi, I'm new in Fluent and Heat transfer. I'm trying to simulate a 2D natural convection from a horizontal cylinder in an enclosed vertical rectangle cavity. The cylinder's diameter is 40mm and the cavity's dimensions is 760mm in height and 260mm in width. My questions are
  • How do I set and calculate the Rayleigh number? What is the characteristic length? Will it be the diameter of cylinder or the length or height of the cavity? If I want to increased or decreased the Ra number, what value can I play around with?
  • How do we calculate the bulk temperature, to be input in reference value? I have tried to use mass-weighted average temperature of the fluid as the input, but the Nusselt number is lower than the value that i found in literature. Someone suggested to find the bulk temperature outside the the boundary layer, but I'm not sure how to do that.
Please help me in this matter. I never use CFD software before. Thank you!
azizi0407 is offline   Reply With Quote
Old   August 22, 2016, 00:27
a0407
Help pls..
Old   August 22, 2016, 03:51
Mustafa
Mohawk is on a distinguished road
http://adf.ly/1dLnuNThis can help
Mohawk is offline   Reply With Quote
Old   August 22, 2016, 04:43
a0407
Hi Mohawk, thank you for your reply. I been to that page before. But it doesn't mention what to use for the characteristic length etc. plus the geometry file cant be open.
fluent, natural convection, rayleigh number
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
characteristic Length CFD MAN Main CFD Forum 3 September 11, 2002 07:26
