September 8, 2016, 05:08 |
How to create multiple points in fluent
Jianhua.Liu
Rep Power: 9 |
Hello everyone ! I have lots of points coordinates, and I want to create these points in fluent, and export these points pressure values.It is lots of points , what is an easy way to achieve it?Thank you in advance!
September 8, 2016, 07:14 |
My usual approach is to use a scripting language (say, octave/MATLAB) to produce a journal which will achieve that.
Still, this is the wrong forum to ask. A dedicated Fluent one exists. |
September 8, 2016, 08:14 |
Jianhua.Liu
Rep Power: 9 |
It is very kind of you ! But I am new in fluent , can you give me an example or some materials to learn that ? Thank you!
September 8, 2016, 12:31 |
#4 | |
After that you should realize that the journal commands exactly fit the Fluent Text User Interface (TUI) commands. So, either by looking into the manual or, better, by trial and error, you should try to find the required set of TUI commands needed to, say, define a point and use that point as you want for a monitor. Once you do that, you need to write a script that, in some smart way, can write all the commands you need to, say, enter a lot of point coordinates and define monitors for them. Finally you give the output of the script to Fluent, to read it as a journal. You can find attached a matlab script doing something similar to what you want to do. Honestly, i don't remember what exactly, you should try it by yourself to see how it works. You can obviously change the part where the points are defined to whatever method you have to define your points (reading from file, etc.). Obviously there might be other ways to achieve that (like scheme language in Fluent), but this is my preferred choice. |
September 9, 2016, 20:24 |
#5 | |
Jianhua.Liu
Rep Power: 9 |
November 7, 2022, 08:00 |
Rep Power: 6 |
Hi Liusst
Did you achieve this? I am trying to do this exactly. Can you please help? Regards |
January 3, 2023, 10:56 |
#7 | |
Rav
I then paste these on the console after navigating to "surface/" or include it in my journal file. |
January 3, 2023, 11:21 |
Rep Power: 6 |
Hi rav-nu
Thanks for your message. Yes, it worked out using the journal file. Now, is there a way to do it for CFD-post then? Regards |
Multiple cell zones in FLUENT | bluemonkee | FLUENT | 14 | May 23, 2017 00:02 |
How to create matching mesh zones so that periodic boundary can be created in Fluent | cgoodale1 | STAR-CCM+ | 3 | February 29, 2016 12:34 |
How to Create a Multiple Point Vortice Vector Field | AHutchison | Main CFD Forum | 0 | July 29, 2013 23:38 |
Multiple probe points | oyvinl | CFX | 1 | February 21, 2011 20:36 |
create a probe with fluent | Aenseeiht | FLUENT | 3 | April 29, 2010 03:27 |
