November 2, 2016, 14:14 |
co2 characterization membrane in fluent
jawad
Rep Power: 9 |
i am working on co2 characterization membrane in fluent..............are there any built in functions for membranes in fluent?.............if not then for writing membrane UDF any user guide available?
July 21, 2017, 06:59 |
zobekenobe
Define the membrane as a porous medium. Go to cell zone conditions and select the membrane and check on the Porous Zone thus enabling it as a Porous Medium.
Go to the TAB Porous Zone below and you can define the porosity. Select the component from phases for the porous media and select the viscous resistance and the permeability for through the Porous Medium. You can also write a UDF for defining the permeation flux, I'm working on that presently will update you whenever I'm done. |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
how to define membrane layer boundary in gambit and fluent | RICHA | FLUENT | 2 | March 15, 2012 09:37 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
