how to give swirl flow in 3D cylinder by using fluent 6.3 |
June 3, 2012, 07:12 |
shivammaurya
hi
i am trying to give swirl flow of different swirl no. like 0.4,0.8,1.4,2.7 etc using fluent 6.3. In 3d cylinder body how can i give swirl flow. suggest me procedure please.... thanks in advance |
June 3, 2012, 13:13 |
#2 | |
Lucky
Rep Power: 66 |
you can specify any number of velocities, wall shear stresses, or applying moving walls to get swirl flows. it is rather straight forward. there is nothing special about swirl, it is just velocity in a different direction and you just proceed with that in mind. If you are trying to apply swirl to a plane inlet velocity, then it is a little more difficult. |
June 3, 2012, 15:09 |
#3 | |
shivammaurya
I want to give swirl velocity with axial velocity from inlet face as shown in diagram... wts procedure for it??????? |
June 3, 2012, 19:54 |
Lucky
Rep Power: 66 |
You can apply "swirl" through the velocity inlet boundary condition settings
Choose components as your velocity specification method, and use a local cylindrical coordinate system specify your cylindrical coordinate system and then specify the angular velocity to get the swirl number you are looking for. Obviously this method only works for constant swirl. If you want varying swirl number you need to do more work. |
January 28, 2019, 04:52 |
Rep Power: 7 |
Hii, Could you please elaborate on this.
I want to model a swirl diffuser in a room, therefore I need to add a constant swirling effect on the flat side of the cylindrical diffuser on the ceiling, so that the air can distribute in a swirling flow to the room. I chose a velocity inlet BC at the inlet where the swirl has to be created, Please tell me what inputs I need to input to get the desired swirling effect for the diffuser. Thankyou. |
Viscoelastic flow modeling in Fluent | Ankur Navra | FLUENT | 3 | July 26, 2013 05:56 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
BCs in Fluent for flow inside a cylinder. | MikeTichondrius | FLUENT | 0 | July 13, 2011 09:57 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
