ERROR on a simple exemple: temperature limited to 5000K in .... |
November 9, 2016, 18:19 |
Julien J
Rep Power: 9 |
Hello dear experts !
Sorry for bothering you, I'm totally blocked. I cannot converge the energy equation because of this error: "temperature limited to 5000 K in (4millions cells) in zone ..." I'm working on a simple stuff: this is a rectangular cross section channel, where a band is providing an heat generation of 33 kW/m2 (ie 3W/cm2) other walls are adiabatics. The fluid is an oil I ve properly defined According to similar topics, I've checked and tried few things: *BC: - oil : inlet 2.5 m/s at 403K - the face is providing 33kW/m2 https://drive.google.com/open?id=0B0...FMMFk0NU5sbjNn *Mesh: - This is a simple "sweep method" , excellent quality (max skewness 0.11 etc..) - the first cell height has been calculated for considering the dynamic BL (inflation) Finally, my mesh consists of 7 millions cells (the problem is on 4 million!) - URF is 1 by default, I've tried til 0.8 or 0.7 - i've tried this stuff : "(rpsetvar 'temperature/secondary-gradient? #f)" It converges without energy equation. Then, if I active it after having the flow simulation, it doesnt work. This is my first day at work, since, I have ever pratised Fluent during 6 months..I dont know what happens, HELP ME Pleaaseeee Thank you by advance. Julien |
November 10, 2016, 11:14 |
Hannes
Rep Power: 9 |
Hm... could be the "heat flux" boundary condition. Maybe try to run some iterations with a constant wall temperature (an initual guess) at first an then switch to the heat flux bc.
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Temperature limited to 1.000000e+00 | xh110120 | FLUENT | 4 | June 21, 2016 03:22 |
temperature limited to ... Combustion simualtion | normanwangliang | Main CFD Forum | 1 | August 27, 2014 13:31 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
why absolute pressure and temperature limited to 1.000000e+00? | wildli | FLUENT | 1 | January 28, 2010 01:25 |
