problem with applying boundary conditions
Old   November 17, 2016, 06:34
Default problem with applying boundary conditions
Adarsh Nair
Adarsh nair is on a distinguished road
Guys in doing a simulation on disc brake,I created a diamsc geometry inside another disc shaped air geometry.I have to input heat flux from disc surface,so I created 2 surface for heat input on disc surface but to create interface be disc and air I'm using the same surface again .so during meshing error msg occurs and says overlap of same surface.
Then I try to do without doing interface ,even then the solver is taking the heat input surface default as interface and I cannot apply thermal properties.
Plz suggest me a solution.
Adarsh nair is offline   Reply With Quote
Old   November 17, 2016, 06:37
Onur Özcan
oozcan is on a distinguished road
Please, post your geo and split it up and show us what you talk about on your geo.
oozcan is offline   Reply With Quote
Old   November 20, 2016, 06:47
Default I need a tutorial or source to setup my premixed ignition combustion.
hasan
Hamzeh Salehpour is on a distinguished road
In a vessel which has a vent(as wall in the first step and then as output in the second step),premixed reactants as natural gas (Methane) in ambient conditions will be exploded with an ignition source (adiabatic) and after a specific Pressure Vent will be removed and the second step will be started, some burned gases will go out and because of more air/oxygen bigger explosion will occur (while the Vent is open)...
I don´t know if I can setup Fluent in the first step (when it has no inlet) and simulate ignition,
also, if I can use the Vent simultaneously for input and output in the second step...?
Can someone guide me how can I be inform about a tutorial or source to setup my simulation in Fluent? - ResearchGate. Available from: https://www.researchgate.net/post/Ca...tion_in_Fluent [accessed Nov 20, 2016].
Hamzeh Salehpour is offline   Reply With Quote
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Problem Applying Boundary Conditions parekhharshj@gmail.com Main CFD Forum 0 July 9, 2014 02:27
Boundary Conditions problem o_mars_2010 Main CFD Forum 2 July 8, 2013 02:10
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
