How to set unsteady turbulent inlet velocity using the result of another simulation? |
December 26, 2016, 19:00 |
Rep Power: 9 |
Hey everyone,
I want to simulate a turbulent jet flow with different model in Fluent. And the simulation should have an unsteady turbulent inlet velocity profile at the source which I plan to achieve by performing a separate periodic pipe flow simulation. Specifically, the inflow at the jet source will be prescribed as an unsteady boundary condition derived from a separate simulation of turbulent pipe flow with the same Reynolds number. Then the velocity field will be recorded across a single cross-section of a periodic pipe flow simulation at each time step, after the simulation reached a statistically steady state. This recording will be then interpolated onto the boundary cell face at the fountain source in the fountain simulation at each time step. I am wondering if this can be achieved in Fluent and how? Thank you so much. |
December 27, 2016, 12:10 |
Lucky
Rep Power: 66 |
Check out how to do a transient profile.
That is, write a "profile" from the source simulation and then read that profile into your turbulent jet simulation. |
December 27, 2016, 17:36 |
Rep Power: 9 |
fluent, turbulent jet, udf, unsteady inlet velocity |
3D Turbulent Velocity at Inlet | twolf59 | Fluent UDF and Scheme Programming | 4 | December 17, 2014 12:41 |
How to prescribe fully developed turbulent velocity profile at inlet? | nore5 | OpenFOAM Running, Solving & CFD | 1 | February 22, 2013 09:30 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 22:46 |
How to assign the inlet B.C using a bunch of data set for an unsteady problem? | ali8500 | CFX | 3 | March 28, 2012 18:41 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
