Getting same output values for different values of parameters in Workbench |
November 2, 2013, 06:25 |
Harshal
Rep Power: 12 |
Hello all,
I'm trying to simulate an airfoil configuration in Ansys Workbench with Fluent. I have defined the angle of attack as the input parameter. I have also defined the wind resistance and downforce (I'm simulating for a race car) as output parameters. I have given the angle of attack as 10, 20,30 (deg.) and so on but I get the same values for downforce and air resistance. Can anyone tell me how to solve this problem ? Thank You !! |
November 4, 2013, 08:31 |
Rep Power: 12 |
I have been having a similar issue with output parameters giving the same values despite different input values. I did discover that if you export the files (click the box to the right on the parameter screen for export) and then go into them individually they have the correct results calculated - ie. open up fluent in the individual files, go to reports and print the results you're interested in, they will be correct. I have not yet been able to figure out why the answers do not display correctly in the parameter screen of the original file though. Any help would be greatly appreciated.
November 4, 2013, 10:38 |
Andrew Kokemoor
Rep Power: 13 |
The interaction between Fluent and Workbench after solving is a little confusing. What's happened to me, and is probably what's happening for you, is that the output parameters are created in Fluent and Workbench, but are only saved in Workbench. If you open Fluent again and go to Parameters... the output parameters you defined earlier will be missing.
When I did this in versions 12 and 13, saving the project from Fluent after defining the output parameters did the trick, and it'll probably still work in later versions. More reliably, I've started calculating all my output parameters in CFD-Post instead. CFD-Post lets you define more complicated expressions for output parameters, too. |
November 4, 2013, 22:29 |
tangyu
how can i download the pdf ?
thank you |
November 8, 2013, 15:28 |
Harshal
Rep Power: 12 |
Thank You all for your replies. I'll try this approach ! Also, if I find a better way, I'll post it here.
March 19, 2015, 07:37 |
#6 | |
Pierre
Rep Power: 11 |
Did you find a better solution to this problem? |
January 17, 2017, 09:26 |
#7 | |
Héctor Lodoso
Rep Power: 10 |
Best regards! Héctor Lodoso |
airfoil, fluent, parameters, workbench |
Changing Workbench Output Parameters - Update without re-solving? | murx | CFX | 3 | June 5, 2013 09:46 |
[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench | la7low | ANSYS Meshing & Geometry | 2 | February 21, 2011 15:12 |
exchange of parameter values between component systems in Workbench | la7low | CFX | 0 | January 17, 2011 10:28 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
seting values for coefficients and parameters | Arvanitidis Mark | Phoenics | 0 | June 3, 2003 06:45 |
