Use of steam in Fluent
Old   January 6, 2008, 22:40
Default Use of steam in Fluent
Ramu Maddi
Any one can help how to use steam as material in fluent. I have seen H2o vapuour in the material list. This can be used at as substitute of steam? Please calrify.
Old   January 8, 2008, 14:14
Default Re: Use of steam in Fluent
Vijay
Dear Freind,
Just give the values of steam in material properties panel while closing overwrite the properties of air, so that u can use properties of steam
Old   January 8, 2008, 23:03
Ramu Maddi
But the properties of steam will vary for different temperatures and pressures. In my domain wide range of pressure and temperature is present. And in my domain the steam enters as dry steam and leaves as wet steam. could you help me.
Old   January 9, 2008, 07:07
Glenn
I was confused by your words above referring to dry and wet steam. Please be aware...steam is 100% water. It is not "humid air" or "wet air". Is that possibly what you were thinking?
Old   January 9, 2008, 07:57
RAMU MADDI
steam is 100% saturated it is called dry steam, and when there is some moisture it is called wet steam
Old   August 12, 2010, 05:00
Default wet steam model
maryam
salam is on a distinguished road
hello everyone,
I have a real gas contains vapor water as my material that in my model water condensation will occur. please tell me if i can use the "wet steam" model in my simulation. if yes, can I use the srk eos as udf with wet steam model because the pressure in my work is very high.
thanks a lot
salam is offline   Reply With Quote
Old   March 31, 2017, 00:41
Default water to steam model generation
RAHUL R M
rahulsuryarm@gmail.com is on a distinguished road
hello,
what are the steps to be taken to create a model which convert water to steam.
rahulsuryarm@gmail.com is offline   Reply With Quote
Old   January 11, 2008, 02:32
Vijay
Dear Friend,
Then u can use polynomial type of material properties, just take the matreial properties in excel then draw an graph and get the values of coeff from graphs then give that values..... This will help u surely bye.....
Vijay
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Superheat Steam in FLUENT? Negin FLUENT 6 February 16, 2016 09:08
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
