Nozzle exhausted to atmosphere
Old   March 15, 2017, 20:16
Smile Nozzle exhausted to atmosphere
Venkatraman Nagarajan
Venkatraman Nagarajan is on a distinguished road
Hello I am doing a thesis related to truncated aerospike nozzle.All I have to do is put the aerospike inside an enclosure and perform a flow simulation as per nozzle specifications.The enclosure is a rectangle and all of these is done in 2D.I am doing a compressible flow supersonic analysis. I am getting a perfect solution if I keep the bottom of the rectangle as a pressure outlet but I am not getting a good solution if I change the type of the left and right sides of the rectangle to pressure outlets in addition to having the bottom side as a pressure outlet.Should I use a far field approximation or do I keep changing the limits,urf and courant number?
In the attachment i want sides 1,2,3 to be pressure outlets.Thanks in advance.
Venkatraman Nagarajan is offline   Reply With Quote
Output from a Nozzle to Atmosphere pmccourt ANSYS 0 June 16, 2016 08:59
Problem: Convergent- Divergent Nozzle Venting to Atmosphere JohnPeclet FLUENT 2 January 13, 2015 18:57
Help needed to setup CD nozzle exhausting to atmosphere sangrampp FLUENT 10 January 27, 2011 11:06
Boundary condition on 3D Supersonic nozzle problem with atmosphere dokeun FLUENT 0 April 1, 2010 21:59
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
