April 12, 2017, 09:02 |
Mass Flow Rate
Giovanni
Rep Power: 9 |
Hi everyone! I'm new to fluent and im practicing with some simple exercises. I would like to ask you what's the meaning of this plot :
Are these the plot of continuity equation? Or what? |
April 12, 2017, 15:12 |
Lucky
Rep Power: 66 |
Are these someone else's plot? Unfortunately without further details they don't really mean anything.
Someone has plotted the mass-flow rate on some arbitrary surface using a surface monitor. However, we don't know what type of averaging it is. I'm also not sure why a surface monitor is used and not a flux report. Finally it is plotted for vs flow-time and vs iteration on two separate plots for two different simulations. The top is transient and the bottom is a steady simulation. That's all it means. You can imagine I show you a waveform and ask you what it means... It could be anything. It could be the prices in the stock market or it could be my haertbeat. |
April 13, 2017, 03:10 |
Giovanni
Rep Power: 9 |
Hi , i'm trying to do the chapter 6 of the fluent tutorial guide at page 257 : https://www.google.it/url?sa=t&rct=j...qEhLA00ozzMKlQ
As you said one plot is for the steady solution and one for the transient solution . I'd like to know the physical meaning of these charts. Thanks |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 3, 2016 23:08 |
trying to perform accurate mass flow rate sampling through hot-film probe | UTA_ARC | ANSYS | 0 | December 2, 2015 13:20 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
