April 21, 2017, 05:55 |
Warning: Incorrect Specific Heat value
Marco Seid
Rep Power: 9 |
Hi everyone,
I am trying to solve a problem regarding species transport without reactions. So I've turned on the species transport model and made my mixture material. For my mixture properties I have:
For each of the fluid materials that comprise the mixture I have:
According to the user guide, this should be ok: https://www.sharcnet.ca/Software/Ans...p_mixture.html "Define the specific heat capacity for each of the fluid materials that comprise the mixture. You may define constant or (if applicable) temperature-dependent heat capacities for the individual species. You may also use kinetic theory for the individual heat capacities, if applicable." However, when I ran the simulation, before every iteration, it says "Warning: Incorrect Specific Heat value" literally over 200 times. If it is relevant, I am using the Pressure-Based Solver, solving the energy, standard k-e and species transport models with the coupled pressure-velocity coupling scheme. I am also using Fluent 18.0 Thanks for reading |
April 21, 2017, 10:15 |
Lucky
Rep Power: 66 |
Honestly I don't see anything wrong with what you're doing. But when you select kinetic theory for transport properties, you must input give the Lennard-Jones parameters and degrees of freedom. Did you do this?
That's correct. You selected ideal-gas so the density is calculated from the Molecular weight. The molecular weight user input plays the role of a user input for density. |
April 21, 2017, 18:33 |
Marco Seid
Rep Power: 9 |
Thanks for your reply LuckyTran. I didnt change the L-J parameters or degrees of freedom for any material because all my materials were selected from the Fluent database. So by default, they already had values for the kinetic theory inputs (although degrees of freedom = 0 for every material).
November 15, 2018, 05:27 |
#4 | |
MMSQ
Rep Power: 7 |
I am encountering the same problem as you mentioned. did you able to overcome the said problem? |
November 15, 2018, 05:41 |
Marco Seid
Rep Power: 9 |
October 22, 2019, 22:43 |
Rep Power: 6 |
You will get the message "Warning: Incorrect Specific Heat value" when you choose Cp : kinetic-theory if you leave the degrees of freedom = 0. If you set degrees of freedom for air to 5, for example, then the message "Warning: Incorrect Specific Heat value" disappears. In this case, cp would equal cp=1/2*(8.314/28.966e-3)*(5+2)=1004.6 J/(kg*K). -DW |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
How to use setField to create sphere | sega | OpenFOAM Pre-Processing | 38 | January 13, 2022 00:39 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 05:19 |
