Problem with water tank stratification.
Old   May 20, 2017, 13:28
Default Problem with water tank stratification.
Lukasz
lukasp is on a distinguished road
Hello
I'm trying to perform an analysis of stratification in tank filled completely with water.
There are two pressure outlets, one on the top of tank and second at the bottom.
There is one velocity-inlet in the middle of tank(with 60 Celsius). Starting temperature is 10 Celsius. The problem is close to uniform temperature distribution across whole tank- as shown on the picture.
I'm using transient analysis, I turned on gravity, as for models Energy equation is on, I use realizable k-e, water properties are defined using piecewise-linear.
Solution method is SIMPLE.
Any ideas why there is no stratification in resaults ?
Best Regards
Lukas
lukasp is offline   Reply With Quote
Old   May 21, 2017, 06:48
Lukasz
I tried to set up second, simplified simulation (2D, with simplified geometry and smaller time step),and I got resaults as shown on the picture. I would seem as the hot water is going to the bottom instead of top of tank.
I got properties of water from this page:
http://www2.bren.ucsb.edu/~dturney/W...100Celcius.pdf
I also checked it on some others.
Thanks in advance
Lukasz
coaxial jet flow into an open water tank sreesha FLUENT 0 January 26, 2017 14:29
Best tutorial for water storage tank calaba OpenFOAM Running, Solving & CFD 0 June 1, 2016 10:14
Pressure BCs for rasInterFoam tank fillingdraining problem kwardle OpenFOAM Running, Solving & CFD 8 September 17, 2008 14:37
modeling spilling of water from a tank jemteo CFX 6 June 25, 2006 19:33
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
