How to check residuals in UDF for dynamic mesh?
Old   May 25, 2017, 14:00
Default How to check residuals in UDF for dynamic mesh?
Prikane
Prikane is on a distinguished road
Dear colleagues,
I am working on transient problem in Fluent. After applying UDF for dynamic mesh and after finishing first time step (with 20 iterations per time step), on the beginning of second time step I should check whether the solution converged (residuals < 0.001). If solution did not converge I should not move mesh and if solution convergence happened boundary nodes on which UDF for dynamic mesh is applied should move. And this procedure should repeat each next step.
How to check equation residuals in UDF for dynamic mesh - is there any function?
Or is there any other way? For example, can I somehow set that my UDF for dynamic mesh is only applied when solution of convergence is achieved?
Many thanks in advance for helping me.
Kind regards,
Prikane
Prikane is offline   Reply With Quote
Old   May 6, 2019, 07:52
ana86 is on a distinguished road
Originally Posted by Prikane View Post
Dear colleagues,
Kind regards,
Prikane
Did you solve your problem?
ana86 is offline   Reply With Quote
Old   May 6, 2019, 08:26
Prikane
Hey Ana86,
Yes, I have solved the problem by following instructions given in the following two links:
http://www.eureka.im/1087.html
residual storage in FLUENT
The explained procedure worked for me! Good luck!
Kind regards,
Prikane
Old   May 8, 2019, 09:33
Thank you
check residuals, convergence, fluent, udf
How to check convergence in UDF for dynamic mesh Prikane FLUENT 0 October 21, 2016 03:25
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
