ANSYS Fluent (error in run calculation)
Like Tree1Likes
  • 1 Post By vinerm
Old   July 11, 2017, 04:07
Post ANSYS Fluent (error in run calculation)
iran
soleimanian is on a distinguished road
Hi
I want to simulate structure under wind flow in ANSYS Fluent.
for meshing, use of ICEM and hexahdral.
in set up my boundary were :
inlet=velocity
outlet=outflow
wall=wall (shear=0)
top=wall (shear=0)
building=wall (shear=0)
bottom=wall (shear=0)
K-epsilon model selected.
but when it run, see 3 things:
1. continuity show large number and didn't converged.
2. reversed flow from some faces in per iteration.
3. turbulent viscosity limited to viscosity ratio.
I don't know why appear their, and need to help for solve this error.
thanks for answering.
soleimanian is offline   Reply With Quote
Old   July 11, 2017, 08:11
divergence is on a distinguished road
Check that your mass balance is correct. You could also check with pathlines starting from your inlet that the flow is more or less realistic. Check that there are no potential troublemakers in your mesh (bad quality cells, mysterious gaps or overlapping volumes). Check your URFs in case that they would be too high for your case.
divergence is offline   Reply With Quote
Old   July 11, 2017, 11:22
iran
may you explain more, because i know little about ANSYS fluent.
and please illustrate step by step check items you said?
or introduce reference for do them.
thanks a lot.
Old   July 15, 2017, 00:16
iran
thanks a lot.
Old   July 17, 2017, 03:13
I would recommend that you would refer for instance the ANSYS Fluent User Guide, which holds vast amount of important information. This document contains also tips on how to do many of the checks I mentioned. Mass balance is checked as the difference of inlet and outlet mass flows and URF is an acronym for under-relaxation factors. ANSYS probably offers many basic level tutorials, in which you can try out many of the said tools.
Old   July 18, 2017, 00:07
iran
thank you
Old   April 2, 2020, 12:33
Nourhan Bahgat
Nourhan Bahgat is on a distinguished road
Error when I run the calculation on FLUENT
please anyone can help me what is the problem in this run so not convergence right low 1e-6
Nourhan Bahgat is offline   Reply With Quote
Old   April 6, 2020, 05:29
Default Error
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What is the error? The attached image does not show any error. Furthermore, do not expect the residuals to drop to 1e-6. Even 1e-3 or 1e-4 might be good enough. It depends up on the values of the field variables. E.g., if velocity or pressure or temperature have very small value, such as, velocity being close to 0.1 m/s, then 1e-3 is not good enough and residuals should drop to at least 1e-4. But 1e-6 is not always required.
Nourhan Bahgat likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Quick Question on Calculation Time Davitt COMSOL 0 January 14, 2016 14:16
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
Error to proceed to Run Calculation bubuchacha FLUENT 2 February 7, 2013 00:35
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
