September 20, 2017, 05:22 |
Sliding Mesh: Changing Interface
Philipp Doll
Rep Power: 8 |
Hi Guys,
I am new to the forum, even if I used it many times to find solutions for my problems. But now I have a problem where I couldn't find any solution. I attached some screenshots with my post to make my problem better to understand: The green zone is a static incompressible fluid ring. The grey zone rotates. The two zones are connected by a static orifice, so there is an interface with relative velocity (marked by the black box). My problem is, that I have no idea how to model that contact. I am used to Frame Motion, Mesh Motion and Sliding Interfaces, but all I did till today were problems, where the interfaces are always in contact to each other. Here, the interface of the orifice is not always in contact with the same area of the interface of the rotational zone. An idea that I have is to "cut" the rotational zone in an inner and outer rotational zone, where the outer zone includes the static areas, too. Then, using frame motion, put zero rotation to the outer parts and frame motion to the inner part. What do you think...? Any other ideas? Thanks a lot already in advance! |
September 20, 2017, 05:25 |
Philipp Doll
Rep Power: 8 |
Sorry, my upload didn't work...My sytem just consists of two fluid rins, connected by a radial orifice...that's it
September 20, 2017, 05:28 |
Philipp Doll
Rep Power: 8 |
I think now the upload should have worked
September 22, 2017, 03:30 |
Philipp Doll
Rep Power: 8 |
No idea or suggestions...?
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
2D ship motion in cfx with sliding mesh: free surface displace with sliding interface | esmail | CFX | 3 | July 4, 2015 08:46 |
non-conformal mesh interface/ sliding mesh interface | liladhar | Main CFD Forum | 0 | March 18, 2013 23:41 |
