Vertical Axis Wind Turbine (VAWT)
Old   December 7, 2017, 02:06
Default Vertical Axis Wind Turbine (VAWT)
TheMightySpartan is on a distinguished road
Hi Guys, really hope you can help me.
I am working on a 2D based Savonius VAWT which is a drag based torque generation device. My issue is that as I increase tip speed ratio, power generation climbs exponentially to efficiencies above the 59% betz limit, also, literature shows that Savonius VAWTs typically don't have efficiencies higher than 30%.
I am currently using the K-ω SST model as all the journals say this is better for separated flows. My air values are as standard from ansys fluent.
Has anyone got any past experiences with a problem like this?
My task is to optimize the design of a NACA 7715 Savonius VAWT, pitch angle, no. of blades etc. and it will be used in a VAWT cluster later in my studies.
Thanks for any help!!
TheMightySpartan is offline   Reply With Quote
Vertical Axis Wind Turbine (VAWT) verification bahieu STAR-CCM+ 6 March 18, 2020 05:32
Need to output surface pressure on blades in a vertical axis wind turbine kmallick OpenFOAM Post-Processing 1 October 21, 2018 23:08
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 06:13
Vertical Axis Wind Turbine (VAWT) simulation Jorge22 CFX 5 November 18, 2017 05:18
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 04:38
