TUI Inputfile - Fluent would skip some lines
Old   December 13, 2017, 07:26
Default TUI Inputfile - Fluent would skip some lines
CWL
cwl6750084 is on a distinguished road
I wonder if anyone can shed some light on the following. For some reason, Fluent would not write the output files at the end of the simulation. It would always skip the lines file/write-case and file/write-data. I am wondering what could be the reason.
Thanks.
file/read-case Small-Case.cas.gz
file/read-data Small-Case.dat.gz
file/auto-save/data-frequency 50
file/auto-save/root-name Small-Case.dat.gz
solve/set/flow-warnings no
solve/set/time-step 1.e-3
solve/dti 2025 20
file/write-case Small-Case-Final_%t.cas.gz
file/confirm-overwrite yes
file/write-data Small-Case-Final_%t.dat.gz
exit yes
cwl6750084 is offline   Reply With Quote
Old   December 15, 2017, 17:49
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
file/confirm-overwrite yes/no is an option to ask for user confirmation, it does not answer the yes/no
you need to do something like:
file/write-case Small-Case-Final_%t.cas.gz ok
LuckyTran is offline   Reply With Quote
Old   December 17, 2017, 08:43
CWL
Thanks for your suggestion. I changed the line, however, the write out lines are still skipped - there are still no output files being written for some reason.
Old   December 19, 2017, 15:39
CWL
Thanks LuckyTran for point that out. Actually, I realized the user confirmation should not be asked in the first place since it is write to a new file. Indeed, 4 yes are supposed to be included at the end of the solve/dti line. The software went ahead and did what it should have done without the four yes caused the oversight. I saw the halt due to end of input file message after reading the reply and figured out what could have gone wrong. Thanks and Merry Christmas.
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 05:32
change default path of result file using TUI in fluent jumaah FLUENT 3 May 27, 2017 21:04
Fluent TUI command, How to do it? Ash Kot FLUENT 2 October 17, 2016 13:42
TUI to replace mesh in fluent 16 Jelos.ch FLUENT 0 November 29, 2015 16:24
Error with FLUENT TUI transient-export function DarrenC FLUENT 0 March 14, 2011 17:30
