January 12, 2018, 09:46 |
Flow through pipe - porous media defining
Jigs
Rep Power: 8 |
Hello everyone,
I want to define porosity, i have pressure drop and flow rate. Can anyone help me how to define porous media in ansys fluent? Or how do i calculate parameters to define porosity? Thanks in advance. |
January 12, 2018, 10:20 |
ehsan
Rep Power: 11 |
Simply, you need to define two zones in design modeler, then in fluent you can active the porous zone from the cell zone menu (which actually adds a sink term to the momentum equation ).
Regards, |
January 12, 2018, 10:40 |
Jigs
Rep Power: 8 |
yes i have done that, but what should be my inputs to porous zone parameter. i mean i have pressure drop and flow data. How do i input that in porous zone?
January 12, 2018, 10:56 |
ehsan
Rep Power: 11 |
Usually you need to know the viscous resistance coefficient (in terms of permeability), inertial resistance coefficents ( just if the velocity is high enough), and porosity. Also you have to enter the direction of each coefficient (if the medium is not isotropic). for more info read the following basic tutorial:
https://www.sharcnet.ca/Software/Flu...ug/node276.htm If you have pressure drop and velocity you can calculate the permeabilty from darcy or more comprehensive models (depending on your problem) |
porous, porous domain |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Flow through two combined porous media with diffrent permeability | Sandee | Main CFD Forum | 0 | March 28, 2015 10:35 |
Flow through porous media near well-borne | I_Fedorov | FLUENT | 0 | October 29, 2014 15:05 |
How do model two phase granular flow in Porous media? | bahman | FLUENT | 1 | December 6, 2012 04:39 |
Can LES be used in porous media flow? | Jin | Main CFD Forum | 0 | October 19, 2006 08:50 |
