Need some help
Old   January 11, 2018, 06:38
Default Need some help
GGWPEZ
brucewayne123 is on a distinguished road
Just a little brief of my project. I'm currently simulating winglet (a device attached to the tip of a wing) in order to determine the coefficient of lift and drag. One of my design is a triangular winglet.
When I run the simulation, my residual graph have this thing call "nut" (I think it means turbulent dynamic viscosity) and it's fluctuating. It doesn't converge. At the console in Fluent, it keeps mentioning something about reverse flow. I think it might be due to the sharp end of the triangular winglet and the flow around that region is very turbulent around that area.
The coefficient of lift and drag for this triangular winglet is very large (sometimes about 0.6 sometimes 66 *depends on what number of iteration used, too high the solution diverge instead of converge*), as compared to my other rectangular and trapezoidal shaped design (at 0 degree angle of attack is only about 0.00XXX for trapezoidal and rectangular).
May I know is it possible for aerodynamics expert here to enlighten me how can I fix this issue?
brucewayne123 is offline   Reply With Quote
Old   January 11, 2018, 07:10
Kirill-MIPT's Avatar
Kirill Borodin
Kirill-MIPT is on a distinguished road
Hello! I think it's a good idea to pay attention to the sharp edge. Try a blunt edge instead of the sharp one. Also please show the mesh
Kirill-MIPT is offline   Reply With Quote
Old   January 11, 2018, 08:01
GGWPEZ
Thanks for your advice ...
I wanted to but that computer is currently running on this simulation ...
But the mesh is just a regular 3D C-shaped mesh ...
Edit:
I tried to avoid the sharp edge design by cutting it away. The "reverse flow" no longer shows up in the console. The residual graph also smoothens out alot. But at times when it converges about 1e-3, divergence is showed in the console. The whole thing then jumped back up to 0 again.
# Divergence detected in AMG for pressure coupled: protective actions enabled!
# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!
Old   January 11, 2018, 09:07
Kirill Borodin
Are you sure you distributed the elements on the surface properly (that's why I wanted to see the mesh)? Do you obtain the boundary layer in the solution? Did you try laminar regime?
Old   January 12, 2018, 00:41
GGWPEZ
Okay ...
The mesh are here ...
I'm sorry don't really get your point for the last 2 questions ...
File Type: jpg Screen Shot 01-12-18 at 01.39 PM 001.jpg (115.9 KB, 6 views)
File Type: jpg Screen Shot 01-12-18 at 01.39 PM 002.jpg (175.4 KB, 10 views)
Old   January 12, 2018, 01:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
use goole and youtube to find examples, how the mesh for simulation flow over an Airfoil should looks like.
key words: airfoil, mesh, prism layer, boundary layer
you can find good example in ansys fluent tutorials as well
Best regards
AlexanderZ is offline   Reply With Quote
