tiago
Rep Power: 0 ![]() |
hi to you all.
i need help with a problem. as can be seen from the picture attached i keep getting the same error. so far attempted to: - change the mesh to reduce skewness (so far its at 0.33) - reduce the courant number. - increasing the tempreture at which the computation is performed nothing seems to work, the problem i am trying to solve is a 2d simulation of a turbine tip blade flow, pressure inlet of 1 atmosphere and pressure outlet of 0.8 atmosphere's. computation was first performed using explicit 1st order and then changed to implicit 2nd order where the problem occured. any help i could get with this would be greatly appreciated. |
Display Modes | |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
plotting temperature time graph using ansys workbench fluent | Hithesh | FLUENT | 0 | March 30, 2014 12:30 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
FLUENT to ANSYS Temperature Mapping | swkang | Fluent UDF and Scheme Programming | 0 | April 3, 2010 19:02 |
