stationary-rotating solid to solid interface
Old   February 5, 2018, 10:46
Default stationary-rotating solid to solid interface
robboflea is on a distinguished road
HI all,
I googled a lot for this but it's been hard so far to find an answer to my question.
Does anyone know if Fluent can handle an interface between a rotating and a stationary solid? I do need to setup a transient calculation (involving conjugate heat transfer, so the solid domain is actually meshed and solved for) of a turbine rotor but assuming a zero tip gap between the rotor blade and the shroud. Does anyone know if it is possible in Fluent or a tip gap should always be present?
Thanks a lot for the help,
Rob
robboflea is offline   Reply With Quote
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
