Splitting a model using outlet data
Old   February 20, 2018, 09:32
Default Splitting a model using outlet data
Max
Max-Power is on a distinguished road
Hi!
I'm trying to simulate a system that could be simplified to something like this:
The a) part is a quite big tank that could be considered as stationary given the small mass flow through the pipe.
The b) part, however, is essentially time dependent, as the tank will get filled over time.
The accuracy of the fluid passing through a)'s outlet section (distribution of speed, temperature, etc.) is critical to the problem.
I was wondering if there is a way of recording a)'s stationary outlet results and then use that data as an input for b), decoupling both problems and letting me simulate both cases independently.
Thank you very much.
Max-Power is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 00:51
UDF for transient pressure outlet boundary from data array nathanblank FLUENT 1 June 1, 2015 03:09
How to: take calculated data from one model outlet boundary and use it at other inlet EdgarasM FLUENT 1 October 2, 2014 10:14
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
