filter layer in a water channel
Old   July 28, 2022, 03:12
Default filter layer in a water channel
Vahid
Kavi is on a distinguished road
Dear Ansys user,
I am trying to simulate a line in a water channel (model 2D), which should be able to filter some particles from the flow. the aim is to simulate a line with resistance again some particles (2nd phase).
but I don't know how can I do it, any suggestion?
I know that defining a porous area would be possible. but I want to know, are in Ansys any possibilities to define a specific resistance for the filter? how it should be? should I define a user-defined (UDF) boundary condition for example?
geometry: 2D simple flow channel. inlet outlet and top and bottom as wall, in the middle, a line as the filter.
any help would be appreciated
Regards
Kavi is offline   Reply With Quote
filter layer, porous boundary
[snappyHexMesh] No generation of layer onto zerothickness surface crubio.abujas OpenFOAM Meshing & Mesh Conversion 3 October 25, 2022 03:20
[snappyHexMesh] Optimizing snappyHexMesh for internal (ribbed) channel flow backscatter OpenFOAM Meshing & Mesh Conversion 1 November 5, 2018 13:28
[ICEM] tidal turbine meshing in ICEM inside a water channel eeLio ANSYS Meshing & Geometry 0 January 11, 2018 09:53
[snappyHexMesh] Adding layer 3d wing (y+=1) Dorian1504 OpenFOAM Meshing & Mesh Conversion 4 November 10, 2017 00:56
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
