April 19, 2018, 08:09 |
Propeller blade setting. Is it correct?
Naveen Kumar Gulla
Rep Power: 8 |
Hi everyone,
I'm trying to simulate the propeller blade in fluent using MRF. Basically, I'm trying to get a similar result with the experimental data, to get the thrust and torque. However, the torque that I'm getting is a way too much different than the experimental value. I'm not sure what could have gone wrong. I'll start with explaining the method that I'm using. After some search and reading in the forum, I found that to study a propeller blade, it needs to be segregated into three different sections, the front zone for translation velocity, a rotating zone that contains the propeller blade, and the downstream outlet section. I'm using k-eps model. The figure below shows the setup that I'm currently using for my analysis, Kindly please advice me if there is anything wrong. |
April 19, 2018, 08:11 |
Some more images
Naveen Kumar Gulla
Rep Power: 8 |
Some more images
April 19, 2018, 08:13 |
Some more images2
Naveen Kumar Gulla
Rep Power: 8 |
some more images
April 19, 2018, 08:30 |
please refer to the fluent tutorials, there are plenty of examples also available online.
April 19, 2018, 08:34 |
Naveen Kumar Gulla
Rep Power: 8 |
April 19, 2018, 12:59 |
Kushal Puri
Rep Power: 12 |
April 19, 2018, 13:15 |
Naveen Kumar Gulla
Rep Power: 8 |
April 19, 2018, 13:23 |
Kushal Puri
Rep Power: 12 |
April 22, 2018, 11:19 |
#9 |
Naveen Kumar Gulla
Rep Power: 8 |
April 23, 2018, 07:59 |
#10 | |
Paritosh Vasava
Rep Power: 22 |
Your setup seems ok except that you have set your stationary part as rotating and rotating part as stationary. This is already pointed out by Kushal. The aim of most tutorials is to demonstrate how a certain scenario can be simulated with fluent. All the official Ansys tutorial discuss results and some verification methods briefly. Of course you yourself will have to figure out how you post-process your case to get relevant results. No tutorial will do it for you. I recommend that you go through the rotating machinery training material from Ansys. It has some very good tutorials and theory explanations about frame of reference usage. Here is the link. |
3D CFD simulation of propeller blade - Turbulent viscosity limited to viscosity ratio | Quentin_C | FLUENT | 1 | April 4, 2017 05:32 |
Propeller blade setting. Is it correct? | zizie | FLUENT | 20 | October 16, 2016 10:18 |
[TurboGrid] Slotted rotor Blade using Turbogrid | drcsm | ANSYS Meshing & Geometry | 0 | March 15, 2016 00:26 |
Ansys Matlab integration: 'propeller blade shape optimization' | usamatoson | ANSYS | 1 | November 22, 2015 06:16 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
