[Sponsors] | |||||
Jiffy
Rep Power: 11 ![]() |
Hi everybody,
I´m solving this problem - I have heat source (100 W) in room. I need to set up the release from the heat source as a ratio of convection:radiation = 30:70. I can set up overall heat flux, and Fluent gives me radiative heat flux in post-pro. But when I count the ratio (based on results from fluent), it is about 40:60. Is it posible to set up the ratio directly as (e.g.) boundary condition? Thanks for help, Jiffy |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
Not really, the point of Fluent is to solve transport equations, i.e. to figure out how the heat is transferred. If you want to impose this as a constraint, then you should not be solving transport equations in the first place.
You have to think about why you think the correct heat flux should be 30:70 because Fluent thinks it should be 40:60. Maybe some other boundary condition needs to give. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to assign convective and radiative heat flux separately? | vs1 | OpenFOAM Running, Solving & CFD | 0 | July 18, 2018 09:11 |
| Positive radiative heat flux, negative convective heat flux how can this be ? | hcmosley1 | FLUENT | 0 | April 25, 2018 18:56 |
| Separate Convective and Radiative heat transfer in CFD post using fluent as a solver | Lemanes | FLUENT | 1 | July 6, 2015 11:31 |
| solver radiative and convective heat fluxes in CFD-Post | user | CFX | 3 | August 3, 2010 09:21 |
| Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
