Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: 0
Old   August 22, 2018, 17:21
Default Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: 0
GuilloC is on a distinguished road
Hey, I was trying to do the final calculation in Fluent and this error appear:
Error Object: 0
At first the simulation was running smooth, but after 49 iterations(50 iterations required to auto safe) this problem appeared and it made the simulation to stop. How can I solve it?
P.S: I am using a cluster
Thanks
GuilloC is offline   Reply With Quote
Old   August 22, 2018, 20:14
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check your monitors.
May be this problem comes from there. Most likely, one of your monitors is not defined anywhere
best regards
AlexanderZ is offline   Reply With Quote
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list ddavies FLUENT 12 August 24, 2023 02:05
Error: invalid argument [1]: improper list Ralf Schmidt FLUENT 7 May 29, 2017 05:26
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
