August 23, 2018, 05:57 |
Expressions using input parameters
São Paulo
Hello forum,
I am new to Fluent, having used CFX previously. I am working on a non-dimensionalised problem. As an example, the thermal conductivity of the fluid is 1/sqrt(Ra), where the Rayleigh number is input externally, directly from the project schematic. How can I specify the thermal conductivity as that expression in the setup? I will be conducting a large number of simulations, so I would like not to have to calculate these myself and change everything manually every time. Thanks |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
A UDF for mixture outlet variable derived from two other input parameters? | ebtedaei | FLUENT | 0 | July 12, 2017 02:17 |
Tutorial for running ANSYS/Fluent with continuous input parameters | chaitanya.mokashi | FLUENT | 0 | April 20, 2017 19:41 |
[Workbench] Parameters to control geometry on Workbench | djangana | ANSYS Meshing & Geometry | 2 | September 16, 2013 11:39 |
Parameters rhoSimpleFoam | marcus85 | OpenFOAM Pre-Processing | 0 | May 15, 2013 09:36 |
