Why I cannot calculate the thrust of my nozzle?
Like Tree2Likes
  • 1 Post By Roh
  • 1 Post By blackmask
Old   September 6, 2018, 12:34
Default Why I cannot calculate the thrust of my nozzle?
Roh
Roh is on a distinguished road
Guys
I have an axisymmetric domain that there is a nozzle in there. Here is a sketch of my domain
"Outlet-1" and "Outlet-2" is "Pressure-farfield" boundary condition and "Outlet-3" is "Pressure outlet" boundry condition. The inlet of this domain is also zoomed up and showed. I heard that I can use the properties of the domain to calculate the thrust but my effort failed. Here is the information of my domain that I got from Fluent:
  Mass Flow Rate (kg/s)
  inlet 0.3848487
  outlet1 1.5579536
  outlet2 20.835326
  outlet3 -22.802237
  Net -0.024108255
  Mass-Weighted Average
  Velocity Magnitude (m/s)
  inlet 173.49819
  outlet1 6.1609674
  outlet2 11.367706
  outlet3 110.55185
  Net 62.176956
  Area-Weighted Average
  Static Pressure (pascal)
  inlet 228198.8
  outlet1 111876.66
  outlet2 110103.08
  outlet3 101325
  Net 109679.36
Here is one of my calculation:
I should've been made mistake to calculate the thrust.
Any idea to calculate the thrust would be appreciated!
blackmask likes this.
Roh is offline   Reply With Quote
Old   September 6, 2018, 21:18
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
https://en.wikipedia.org/wiki/Rocket_engine
https://en.wikipedia.org/wiki/Rocket_engine_nozzle
read carefully
best regards
AlexanderZ is offline   Reply With Quote
Old   September 7, 2018, 03:52
Roh
Thank you Alexander for your response,
There is a point about my problem.
To calculate the thrust of a Bell nozzle you can calculate its thrust easily using mass flow rate of the nozzle inlet and velocity at the exit of the nozzle (even you can get avarage pressure to calculate pressure thrust) but calculating the thrust of an Aerospike nozzle is challenging. You remember this topic:
How to calculate centerbody thrust of an aerospike nozzle in Fluent
Now I'm thinking to calculate the thrust using my domain not the nozzle.
Any idea?
Old   September 7, 2018, 05:21
blackmask will become famous soon enough
Hi, Roh, you have set a very good example of asking questions. It makes rather easy for others to understand your point. well done!
Note that the momentum flux is a vector, so you have to use mass-averaged velocity component (axial-velocity in this case since you only interested in thrust) instead of velocity magnitude.
Roh likes this.
blackmask is offline   Reply With Quote
Old   April 8, 2024, 05:37
Jessica
Jessica@123 is on a distinguished road
Any idea?
Hey Roh,
Did you find the answer to the question you posted? I'd appreciate your response.
Thanks
Jessica@123 is offline   Reply With Quote
Old   April 11, 2024, 16:17
Default Aerospike
nahrafx is on a distinguished road
I believe the geometry is from the work of Prasanth P Nair on conical aerospike and bleed effect. Im also working on a project for my undergrad on linear aerospikes and we essentially used the thrust equation of an aerospike from the Rocket Propulsion Elements Textbook by Sutton to compute thrust coefficients.
Refer to the authors paper above and check out the equation used for thrust. Itll provide more clarity.
nahrafx is offline   Reply With Quote
Thrust calculation from cfd data(Numerical Integration) balkrishan Main CFD Forum 4 April 24, 2018 05:45
Nozzle Flow - Divergence Problem Ijaz FLUENT 9 January 11, 2014 04:36
Sonic flow for exhaust nozzle beanlee999 FLUENT 1 May 10, 2012 14:34
calculation of thrust thrugh a pipe with CD nozzle izhar Main CFD Forum 0 February 28, 2009 09:22
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
