October 15, 2018, 19:32 |
Export excel transiet
Pedro Jesus Sanchez
Rep Power: 7 |
Can I export a table of result? I want to export data of a one point. I want a table with one column time and second column for example the value of pressure. What is the proccedure to follow? Thank |
October 15, 2018, 21:34 |
Lucky
Rep Power: 66 |
Create your point (in surfaces). Then create a report and you will have the option to write it to the a file. In old versions you simply created a monitor. In new versions you have to define a monitor and/or a report (two steps).
October 16, 2018, 10:34 |
Pedro Jesus Sanchez
Rep Power: 7 |
Can all this be done once the solution has been calculated?
or is it necessary to do it in set-up before calculating? So me manual please? Last edited by p52sarup; October 16, 2018 at 14:35. |
October 17, 2018, 03:18 |
Leonardo
Rep Power: 8 |
You can do it after the simulations if you save the data at each time step and plot it in Cfd-post. But it is not very practical since the project will be very heavy. The recommended would be monitor only the points of interest and you can visualize it in excel or others.
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
[DesignModeler] Export "Details of Body" in Excel (Scripting) | Kapi | ANSYS Meshing & Geometry | 3 | May 12, 2015 18:34 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
