October 28, 2018, 16:16 |
To fix Static pressure at inlet
Hamed Abdul Majeed
Rep Power: 13 |
Hi
I want to fix my static pressure at the inlet of the domain. There is no inlet boundary condition (as fluent names it) that does that. Can I use a pressure outlet boundary condition at the inlet instead? What would be the implications of doing so...other than to be careful with the direction to avoid Fluent flow reversal errors! |
October 28, 2018, 17:33 |
Lucky
Rep Power: 66 |
It's highly non-physical. The only case where it makes sense to fix the static pressure at the inlet is if the flow is super sonic (and the pressure inlet BC does do this), which is also the implication if you do choose to fix the static pressure. Eventually you will run into another inconsistency. Fluent intentionally doesn't support this boundary condition because it doesn't make sense to do something that doesn't make sense.
October 28, 2018, 17:39 |
#3 | |
Hamed Abdul Majeed
Rep Power: 13 |
I have an incompressible flow through a pipe. At inlet I fix the static pressure, hence, a "pressure-outlet" boundary condition. At outlet I fix the velocity, hence, a "velocity-inlet" boundary condition. Is this still a non-physical problem? I assume this is a well-posed situation! |
October 29, 2018, 07:23 |
#4 | |
Lucky
Rep Power: 66 |
Why not take it a step further and impose a static pressure and velocity at the inlet and have no boundary condition at the outlet? Think about it... I get that sometimes you know all the thermodynamics entering a simulation and want to impose it. But thermodynamics is ignorant of the forces that causes a system to be at or arrive at a state. If you run into a situation where you need to force a static pressure at the inlet, then you are thinking in the thermodynamic mindset and ignoring physical context. You're using the wrong tools for your problem. Can you do it? Yes. But I'm strongly recommending you to figure out how else (i.e. the proper way) to approach the problem. Last edited by LuckyTran; October 31, 2018 at 10:48. |
October 30, 2018, 11:28 |
Hamed Abdul Majeed
Rep Power: 13 |
Thank you...appreciate your response
help with boundary profile in pressure inlet | quiqui | FLUENT | 21 | June 18, 2013 12:55 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
How to achieve constant static pressure in inlet? | Zou Jianfeng | FLUENT | 0 | October 21, 2008 01:55 |
Setting static pressure as the inlet BC | ruined | FLUENT | 1 | March 21, 2008 14:57 |
