To fix Static pressure at inlet
Like Tree2Likes
  • 1 Post By LuckyTran
Old   October 28, 2018, 16:16
Default To fix Static pressure at inlet
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Hi
I want to fix my static pressure at the inlet of the domain. There is no inlet boundary condition (as fluent names it) that does that.
Can I use a pressure outlet boundary condition at the inlet instead?
What would be the implications of doing so...other than to be careful with the direction to avoid Fluent flow reversal errors!
hamed.majeed is offline   Reply With Quote
Old   October 28, 2018, 17:33
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
It's highly non-physical. The only case where it makes sense to fix the static pressure at the inlet is if the flow is super sonic (and the pressure inlet BC does do this), which is also the implication if you do choose to fix the static pressure. Eventually you will run into another inconsistency. Fluent intentionally doesn't support this boundary condition because it doesn't make sense to do something that doesn't make sense.
hamed.majeed likes this.
LuckyTran is offline   Reply With Quote
Old   October 28, 2018, 17:39
Hamed Abdul Majeed
Here is a what-if scenario!
I have an incompressible flow through a pipe.
At inlet I fix the static pressure, hence, a "pressure-outlet" boundary condition.
At outlet I fix the velocity, hence, a "velocity-inlet" boundary condition.
Is this still a non-physical problem? I assume this is a well-posed situation!
Old   October 29, 2018, 07:23
Lucky
The velocity outlet BC is still non-physical because it is a uniform velocity constraint. The hand of God reaches into your simulation and imposes a uniform velocity field at the exit, which doesn't happen in real life (the velocity is whatever it wants to be). This miracle happens while you are solving a boundary value problem pde. Is it mathematically ill-posed? No. But it still requires some divine intervention for any real flow to behave that way. If you choose to use that set of BC's, then that is the implication carried with your result.
Why not take it a step further and impose a static pressure and velocity at the inlet and have no boundary condition at the outlet? Think about it...
I get that sometimes you know all the thermodynamics entering a simulation and want to impose it. But thermodynamics is ignorant of the forces that causes a system to be at or arrive at a state. If you run into a situation where you need to force a static pressure at the inlet, then you are thinking in the thermodynamic mindset and ignoring physical context. You're using the wrong tools for your problem.
Can you do it? Yes. But I'm strongly recommending you to figure out how else (i.e. the proper way) to approach the problem.
Old   October 30, 2018, 11:28
Hamed Abdul Majeed
Thank you...appreciate your response
help with boundary profile in pressure inlet quiqui FLUENT 21 June 18, 2013 12:55
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 01:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
