How to use different fluid materials in fluent? |
November 9, 2018, 07:05 |
Oula
Rep Power: 11 |
Does fluent enable the user to use different materials in one simulation?. I want to model a heating cycle that uses different gasses
The first segment of the cycle, 3NH at specific gas flow rate is used the second segment, H2 and a 3NH at specific gas flow rate for both are used how to set these material and how to tell fluent that use this material now and after specific time use the other materials and mind their flow rate? Is this possible in Fluent? |
November 9, 2018, 08:44 |
Lucky
Rep Power: 66 |
Probably but it's not clear what you are trying model.
You are saying that you have an inlet where at first only 3NH is flowing? And then at some later time, the same inlet now has H2 and 3NH flowing? Then you should use a species transport model and change the boundary condition for the species mass fraction at the particular time. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Connecting three fluid zones in Ansys Fluent 12 | tobiasz | FLUENT | 0 | April 29, 2016 11:43 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent 14 journal script to set fluid parameters | jhome | ANSYS | 0 | April 30, 2012 04:26 |
