November 9, 2018, 11:51 |
Ansys Fluent NOT working
Amit
Rep Power: 7 |
Hello friends,
I have downloaded Ansys student version. I am trying to learn CFD (Fluent). But Fluent is NOT working. Error message as shown in image appears. I tried both serial mode as well as parallel mode but neither worked. Request you to guide/help me to correct/rectify problem. Thankyou, |
November 9, 2018, 12:44 |
Lucky
Rep Power: 66 |
Which mpi are you using? Try a different one. Also make sure you've allowed Fluent through the firewall.
November 9, 2018, 13:03 |
Amit
Rep Power: 7 |
Thanks a lot.
Previously I was using default mpi (of fluent). Then I switched over to intel and msmpi. However error message (in image files) appears. How to allow Fluent through firewall? Also Why Fluent (in serial mode) does not work? |
November 9, 2018, 13:43 |
Lucky
Rep Power: 66 |
You are using Fluent v19. There is no more a serial mode. The serial mode is actually parallel mode using 1 process. Hence the mpi is still called and it fails for the same reason that your parallel mode does not launch.
Actually you can invoke the vanilla serial mode by launching fluent and passing the -t0 flag instead of -t1 or -t3 in your case. But this requires more setup, and it doesn't fix your problem. Why does it say it cannot find the missing files? Can you go there in windows explorer and check? Did you forget to install the pre-reqs before installing Fluent? Specifically visual studio? On the installer there is a little program to check for pre-reqs. Run it. |
November 9, 2018, 22:14 |
Amit
Rep Power: 7 |
Its an auto installation process. All pre-req checked and installation done (by Ansys installer).
I will re-install v19.2 and check. |
November 9, 2018, 22:19 |
Amit
Rep Power: 7 |
All pre-requisites done.
November 9, 2018, 22:59 |
Amit
Rep Power: 7 |
Same problem is still there.
Fluent NOT working. Same error message of MPI. |
November 9, 2018, 23:06 |
Amit
Rep Power: 7 |
Heyy I am running it on windows7. Can it be a problem?
Ansys site shows requirement of windows 10. |
Why ANSYS FLUENT gives me a wrong answer???? | TomFord | Fluent UDF and Scheme Programming | 0 | August 22, 2018 07:12 |
UDF Defining in ANSYS FLUENT 16.2 in Win 10 | Sadegh.A | Fluent UDF and Scheme Programming | 11 | February 15, 2017 14:45 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
FLUENT to ANSYS Temperature Mapping Procedure | schreiberc1 | FLUENT | 0 | June 29, 2006 13:50 |
