Transient Simulation - Fluent remove my case and data |
December 3, 2018, 13:46 |
Hello there!
First of all sorry for my bad english. Im doing a transient simulation and I specify Fluent to save the case and data after 15 time steps. Yesterday, I did 90 time steps (so the program save 6 files of case and data). Today I turn on my computer to continue with my simulation but after open my last case and data file the program delete the previous file (5 files) and I only have my last simulation file. How can I avoid this? How can I continue my simulation without deleting the previous files? Thank you. |
December 4, 2018, 02:54 |
Piotr Prusinski
In order to help you, you need to specify your problem little more extensively. First, are you processing your data under Windows or Linux, then via GUI or with a use of command line (TUI). With or without Workbench environment??? Regards, Piotrek |
December 4, 2018, 04:22 |
ssa
Rep Power: 7 |
I have also had this problem. I don't know why this happens. Before closing the window, check your workbench whether everything is updated or else copy the dat files to some other folder before closing the workbench.
December 4, 2018, 10:49 |
Lucky
Rep Power: 65 |
This is a workbench problem because there's no way Fluent by itself can do this (Fluent doesn't check for existing .cas and .dat files). Unfortunately I don't use workbench to tell you what to do to fix it.
April 22, 2020, 09:20 |
Ricardo Moya Ch.
Try this in Workbench:
Tools>Options>Fluent>(and uncheck "automatically delete old solutions on start of new calculations") That probably will help! |
case, data, delete, file |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Save Solution Data in a Fluent Transient Simulation | asf_card | FLUENT | 3 | September 15, 2015 21:41 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 03:47 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
