How to define Boundary conditions for Quadrature Method of Moment |
February 5, 2019, 11:25 |
Rep Power: 7 |
Hi guys,
I’m working on population balance model and have some issues with the definition of QMOM boundary conditions. I used to work with descretization method and there BC was quite simple to define. It was either a log normal or a manual distribution but here with method of moment it is confusing. I can't understand how to set up a boundary value for each moment. I'm using fluent 18.2 with the mixture multiphase method. The only phenomena occur here is growth rate (2.8e-8 m/s) and the particle min and max size are 1e-7m 1e-5m respectively. Any comment would be highly appreciated. Amir |
fluent, method of moment, population balance model |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
