Asking about Dynamic Mesh
Like Tree1Likes
  • 1 Post By Pham Van Chien
Old   February 17, 2019, 20:35
Default Asking about Dynamic Mesh
Pham Van Chien
Pham Van Chien is on a distinguished road
Dear Experts,
I am trying to simulate the compression process of a 2-stroke engine (pls see the attached file to know the Geometry). I am using the in-cylinder model to simulate the motion of the piston from Crank Angle of 180 deg to C.A of 360 deg.
My simulation including 2 fresh air inlet ports and I made 2 interfaces between 2 inlet port domains and the cylinder domain (as can see in the attached images). During the simulation process, at the time step 53, when the piston reaches the inlet ports, there is the following error occurred:
Error: coalesce_rib_faces: can't interpolate data, zones of different type detected.
Error Object: #f
Why did that error happen? And can anyone pls help me?
Your help will be very helpful to me.
Thank in advance!
Van-Chien Pham
Master312 likes this.
Pham Van Chien is offline   Reply With Quote
Old   May 19, 2022, 04:33
Default same problem
Amir
Master312 is on a distinguished road
Originally Posted by Pham Van Chien View Post
Dear Experts,
Error Object: #f
Thank in advance!
Van-Chien Pham
Master312 is offline   Reply With Quote
Old   May 31, 2022, 09:50
Smile Answer
Amir
Dear Experts,
Error Object: #f
Thank in advance!
Van-Chien Pham
hello dear
you must change your boundary condition of "walls to interface" in "direction" of your interface. in other words you must change all boundary conditions that slide through "motion wall" to interface and then define them in manual interface. in the last you have all boundary conditions of slider with "interface" mode, "no" part of that.
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
Sliding / Dynamic Mesh in heat transfer problem platzhalter FLUENT 0 May 7, 2018 05:25
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 04:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
